carb prob
wildchild27
DR. DISASTER
Etna Green, IN
my picco .26 outlaw doesnt want to take fuel into the carb and when it does it will only run for a few seconds. wat could be the problem?
eric, snap a couple pics of your truck including a pic of the carb throat with the air filter off
when the last time u run your rc ?
i got this similar problem in my friend's traxxas
because he did not run it for long time, and the old fuel in the huse and the carb was as glow.
sorry I don't how to explain what i did :dunno:
English is my second language:cool:
I think you have an air leak in your fuel tank or a bad front engine bearing. I had this mill some time ago and had the same issue. Turns out the bearing was leaky. I wound up replacing it twice in 3 months that would cause it to run for a few seconds and cut out. Take your mill out and do the soapy bubbles test to check your carb and front bearing for leaks.
