- Location
- Worthington, MN
Well I was out breaking in my motor today actually running on the 5th tank just starting to tune it a little bit. This is an a Picco .28 the new version with plastic carb.
Anyhow did a little run by on down the street then went to turn around hit the brakes and went to go and bring it back to me to get a temp. Pulling the throttle it would only hit very low RPM. It picked up enough to roll back to me at about 5mph but thats it. Got it back to me about 40ft. Looked at it and the servo would only pull the Slide out like 1/16".
Played with the linkages pulling on them to see if I could get it out but no its like it's hitting a stop. I then pulled the carb out of the truck to find it not to slide out any further. I pulled the idle screw out thinking it would clear it up but nothing didn't make a difference other than I could spin the slid 360* with out a problem but will in any direction stop at the same spot.
Has anyone seen this before??
