well.. not exactly!
Hi guys, hope all is well! It has been a while since I was last around these parts =)
Anyhoo, my problem. I took my savvy out a couple of weeks back, when it began to make some odd noises from the engine, as if it was running to lean.. well I guess it was because shortly after the carb was hanging on by the fuel line!
God only knows where the bolt went. Can anyone tell me what the part number is for a replacement nut+bolt assembly (I need the black countersunk washers too).
Apart from that, everything seems to be running great.. oh there is a slight problem with the steering, it seems to struggle to turn left but I think that I just need to adjust the spring on the arm so it doesn't slip so much(if you know what I mean)
