capacity levels
80KKA
i've got a turnigy accucel 6 balance charger.
i'm having troubles to work out the actual charge level my batteries are before i start charging them.
i've looked through the online pdf manual, but it doesn't say anything about the charger being able to detect this. once i start charging the capacity charge count starts from zero.
is there anyway i can check battery levels???
p.s [looking at upgrading this charger to one that can charge two batteries simultaneously at a later stage]
I have had that charger a while back. It wont say how many mAh's are left in the batt. However it should still show the voltage. You should be able to guesstimate how much of the batt you have left and when the charge ends you can just calculate how much mAh you had used up to get a better understanding of your run time.
