cant find the bearing you need ?
NITROMITE
Pataskala,Ohio
i am starting a list, so let me know withch ones I'm missing. i will include the actual part # rather than hpi # so you can find them cheaper. i would like to add witch bearing is for what so please help me out with that so i don't have to do more research.
5X10X4 (MR-105-ZZ) clutch bell
Here is a full ceramic 5X10X4 Full ceramic bearing $49.00
6X13X5 (686-2RS) Tranny
Here is a ceramic bearing 6X13X5 (not full ceramic just the balls are ceramic) $29.95
10X16X5 (6700-2RS) differentials
here is a ceramic bearing 10X16X5 (not full ceramic just the balls) $9.95
8X16X5 (688-2RS) Axles and pinions/tranny
here is a full ceramic 8X16X5 Full ceramic bearing $79.00
6X7X2.5 (676ZZ) steering upgrade
ceramic bearings can not be made this small do to the diffaculty
2. Model Car and Buggy Bearings
R144ZZ 3.175x6.35x2.778 ****** FR144ZZ 3.175x6.35x2.778 Flanged
R156ZZ 4.762x7.938x3.175 ****** FR156ZZ 4.762x7.938x3.175 Flanged
R166ZZ 4.762x9.525x3.175 ****** FR166ZZ 4.762x9.525x3.175 Flanged
R168ZZ 6.35x9.525x3.175 ****** FR168ZZ 6.35x9.525x3.175 Flanged
R188ZZ 6.35x12.7x4.762 ****** FR188ZZ 6.35x12.74.762 Flanged
R1810ZZ 7.938x12.7x3.969 ****** FR1810ZZ 7.938x12.7x3.969 Flanged
R1038ZZ 9.525x15.875x3.969 ****** FR1038ZZ 9.525x15.875x3.969 Flanged
R1212ZZ 12.7x19.05x3.969 ****** MR148ZZ 8X14X4
683ZZ 3X7X3 MM ****** F683ZZ 3X7X3 MM
693ZZ 3X9X4 ****** F693ZZ 3X9X4 Flanged
684ZZ 4X9X4 ****** F684ZZ 4X9X4 Flanged
694ZZ 4X11X4 ****** MR105ZZ 5X10X4
624ZZ 4X13X5 ****** MR115ZZ 5X11X4
685ZZ 5X11X5 ****** MR128ZZ 8X12X3.5
695ZZ 5X13X4 ****** MR104ZZ 4X10X4
686ZZ 6X13X5 ****** MR137ZZ 7X13X4
688ZZ 8X16X5 ****** MR95ZZ 5X9X3
MR83ZZ 3X8X3 ****** MF83ZZ 3X8X3 Flanged
MR63ZZ 3X6X2.5 ****** MF63ZZ 3X6X2.5 Flanged
MR74ZZ 4X7X2.5 ****** MF74ZZ 4X7X2.5 Flanged
MR84ZZ 4X8X3 ****** MF84ZZ 4X8X3 Flanged
MR85ZZ 5X8X2.5 ****** MF85ZZ 5X8X2.5 Flanged
6700ZZ 10X15X4 ****** 6701ZZ 12X18X4
6800ZZ 10X19X7 ****** 6801ZZ 12X21X5
3. Model Engine Bearings
Usually they are lubricated by oil mist from the engine and so only have a shield or seal on the side facing outwards.
Often these bearings are required to spin faster than the usual limiting speed for their size, and so they may require features such as increased radial clearance and / or high speed ball retainers (cages) made from a variety of synthetic materials.
FAMOUS SIZE:
Item Dimension STOCKS Item Dimension STOCKS
689ZZ 9X17X5 ****** 607-2RS 7X19X6
6901-2RS 14X25X6 ****** 6801ZZ 12X21X5
697ZZ 7X17X5 ****** 6802ZZ 13X25X6
4. Model Helicopter Bearings
10x16x5mm - differentials (HPI B032)
5x10x4 - clutch bell bearings (HPI B021)
8x16x5 - Axles and pinions (HPI B085)
I can dig some more in a bit.
Bob
so the 5x11x4 is the tranny right
thanks frddyj if you use the part numbers i have put up you can find all kinds of bearings that are not rc related rc bearings are made in japan or china and are junk IMO only run ABEC5 or Better check it out . next I'm going ceramic ABEC 7
pretty kool guy, yeah the list your workin on (abec 5's, links, prices) would be sweet.
clutchbell bearings are 5x10x4, but not sure if you meant the bearings inside the tranny?
But, the Sav X owner's manual that came with my truck has all the sizes listed for it. i'll try to pull out the manny tonight & pm you some sizes if that would help.
good thread btw.
:FarleyParty:
good thread btw.
:FarleyParty:
here are the tranny bearings
and the sizes they give in the manual are worthless because they only use hpi part # if you google the part number i give you, you will end up with other brands of the same bearing and many different quality levels for exampel search (MR-105-ZZ) witch is the clutch bell bearing, and you will end up with many different types of the same size bearing but with better qualities. i know this because i work sales at a bearing factory..
and the sizes they give in the manual are worthless because they only use hpis part #
Ok, try typing the # into google like this .... HPI B023 & you get links with sizes ;)
Bob
thanks for the help. did you get the message that i shiped your bearings? and have you shiped my stuff yet
