mekios
- Athens, Greece
I had a little bashing yesterday, and it seems, my savvy landed on WOT after a small jump. As a result spur gear was stripped... because (i found later), the engine plate cracked!
What would you recommend as a good spur gear and clutch bell setting, so i won't go through lots of spur gears and cb's? (Engine plate will be fixed)
And what was the cause of my engine plate cracking ? (Ok WOT on landing, but that is a bit common situation, will it always tear stuff apart?)
