Brushless Conversion MM
Nate700
Hi guys, I'm a new guy here and have a X 4.6 that I want to go Brushless with. I'm trying to figure out everything I'm going to need to get up and running.
I plan on using the conversion kit that hpi is coming out with along with a MM and 2200 kv, but that may change depending on price.
So my question is can you solder the three wires on the MM or do you have to use the bullet connectors.
Thanks in Advance- Nate
welcome to the forum I don't see why you can't solder them but i think it would be better with bullet connectors if for no other reason it would be easy to remove
Thanks, thats what I was thinking. But I remember reading somewhere about not being able to solder directly to the esc. Just wanted to be 100% sure on it.
