Broken motor mounts
yeroc1982
I got 4 broken mounts that break in the same place always. Think JB weld will hold if i applt and clamp overnite?
where do they keep breaking? and have you looked at the motor plate to see if its bent or cracked? theres got to be a reason for it to keep breaking motor mounts .. and i don't think jb weld will hold if its snapping aluminum itll snap jb weld.. theres got to be a visible reason for it to be breaking i would think... good luck hope you figure it out ..
Actually the motor plate is good. One of those silver aluminum brace arms that go under the motor plate is broken.
+1 with Max
Id almost have to say if you broke a cross member, though it may look straight that mill plate is toast too! Take it out and put it on a flat surface. Any part not touching the surface and it junk...
