breaking alot of dogbone
pat1
can someone please tell me what I am doing wrong? I am breaking dog bones all the time I broke 3 last sunday. I have a lrp z.28 motor and 30K weight oil in the ft diff and 60k oil in the rear diff.I replaced the dog bones with the tsais cv axles and I broke one today in about 30 min please tell me what I am doing wrong.I was breaking them before I put the heavy weight oil in the diffs.
thanks
Pat1
30k isn't really a heavyweight oil .. Just make sure you don't land on the gas from a jump ... If you are using the HD (chrome) dog-bones .. STOP they are junk .. in fact I broke one myself today .. stick with the stock black ones
If you are having a hard time keeping dogs on it CVD's are not where you want to go. You are running alot of power with the LRP. You just need to be careful when comming off jumps about being on the throttle. Also,loosen you slipper a bit then it can slip instead of throwing all the weight at the drive tran, lighter diff oil will help but if your bashing you are runing about where you want to be.
These may help you they are extra heavy duty dogs that will fit between the diff and the wheel. They are actuall designed for the rear center dog on the Extended FLM chassis anyway you decide heres the link:http://www.smfstore.com/product_info.php?cPath=31_63&products_id=1879
