Break in trouble
Tree one
Savage ss 4.6 had the cylinder pinch running 20 % cool power. I am not getting any excess oil out the exhaust. High and low needles as you wood for a new break in. What am I missing.
I'm not understanding the issue. Is the engine starting and you're having issues with it running. Or can you not start the engine because it's hard due to pinch?
For a new engine reset needles to default and warm up engine to 200 F with a heat gun. This will relieve the piston and rod of any stress due to tight pinch. Don't attempt to tune until engine is running and is up to recommended temps.
When tuning get temps up first, set HSN, once that is finalized set LSN, once that is finalized set idle adjustment.
