OK fellas I finally had a chance to break in my savage. I used the heat cycle method but just wanted to know if I did it right. First I heated up the motor the best I could. At first the temps were not getting above 165 degrees, so I raped the head up with a few paper towles ( thats all I had on hand) well I managed to get the temps up to around 200 to about 225. I understand that you are only to heat cycle the motor for about 2-3 minutes for the first 15 or so minutes then increase to about 3-4 minutes until you have 20 to 25 mins heat cycle time. My question is it took about 5 to 7 minutes to reach those temps. I did this about 5 to 6 times. I also made sure that my piston was at BDC each time I shut her down. Do you guys think I ran her too long for the heat cycle method?
