Brakes
N713TL
here is a question . the stock brakes on the XL do they Glaze From heavy Use From High speed runs ? and do water and or Snow make Braking A lot less
Newer model XL 5.9 med fag and polish . 47/19 gear stock Trans And diffs .
I would have to say yes to both, especially with the red glass discs, a light sanding on a piece of 60 grit paper usually removes it tho, personally i run the stainless discs and fiber pads without too much issue...
ok thanks for the tip that's what I'm gunna do because they are black . until I get and put on the steel
