Brake upgrades for svagae help!!
  • Thread starter Thread starter trebreeden
  • Start date Start date
T
trebreeden
Guest
my BRAKES don't work at all on my savage is there any mods i can do to make them work hard
hello again lol a quick and easy fix is replace the brake adjusting spring with a piece of fuel tubing thats a bit longer then the spring its easier for your servo to push the fuel tubing then the spring so your brakes work better,second thing, are you running a hump pack or do you just put the 4 aa batteries in your truck?
i converted it back to the a's because i didnt have charger and what spring do you have pic
well with the aa's your only getting 4.8 vlots of power and with a hump pack your getting 6 volts of power to the throttle/brakes.It doesnt sound like alot of difference but it is... and I'm talking about the spring right behind the dial that you turn to adjust your brakes and if you were planning on just going with a new better brake setup this is the one mentioned above and i would reccomend it as well http://cgi.ebay.ca/HPI-87025-Fiberg...Control_Parts_Accessories&hash=item1e605e85b1
max do you have a pic i really don't under stand wat you saying
so take the plastic peice off an put fuel tubing also my linkage peice not sitting up like that is laying flat
uncrew the adjustment knob and take it off,remove the spring and slide a piece of fuel tubing over the linkage make sure its a bit longer then the spring
so your saying the rod thats standing almost straight up in the pic is lying flat on your truck?
yea its not up like that and the spring you talking bout is that silver one on that pic underneath the break linkage
oh.. so ima do the tubing thing and th break pad stuff
is it the ones on the outside of the tranny or inside
yea it broke so i got another one put on there but it should stand up if its properly in rite?
yea the pad is worn out can you give me a link to buy one
hey shaun can you show me how to get my break linkage like yours
