BP Diff Shiming Question
ajdragon
Hi
I just got two new BP diff's and there seams to be alot of play in them, is this normal? I took them both apart and transfered the two big shims from inside of one diff over too the other so that there are now two on the inside on each side, plus I used some 6mm shims to take up the slop on the outside portion of the out drives. It's all nice and snug now, unfortunately I now have to order new shims inorder to do the other diff.
Also, are the out drives on the BP diffs SHD out drives?
if you have 11mm thick dogbones from each diff to axle then you also have SHD out drives.
and yes there's play in savage bulkheads/diffs that you'll need to shim.
