big bors setting
farmawi
hay guys finally have the big bores for my savy today
but when am start to putting them i notesed that there is a part on the instruction with the number 85510 that is not included with the set and another one that is not exist in the instruction so i put them without that part and without the ball will that distroy them or no????
and i want to ask about the best setting for them is it good with the stock oil wight piston set and a 30wt silicon oil????
i run mine with the 1.6t pistons and 30wt oil and the preload spacers but i forgot the # and my savy is at my dads so i cant check as for the other part what ball are you talking about the one that screws into the a-arm or the shock tower
ya the one that screws into the shock tower
there are supposed the little metal sleeve and the metal ball but the ball is there so the screw fits if not the hole is too big and it wont mount correctly and I'm pretty sure it would cause some damage
ya think so should find the missed parts and mount them correctly
