Big Bore shock question
grtrnd1
Alledonia, Ohio
Ok. I broke alot of stock shocks last summer, and I do mean alot. Bent shaft, broke shafts, split shock bodies, busted caps, etc. I read alot of post that talk about HPI's big bore shock. Seems to be the way to go. Seen Integy aluminum shocks but, seem alot of people are not a fan of Itengy. Will these shocks handle alot of high jumps? Another question is, I see most people are only putting one shock on each corner. Is this fine for racing, or will I have to mount two on each corner for back yard bashing and high flying. Thanks.
Aluminum shock bodies,Thick shafts that are hard to bend! and a bunch of different shock pistons with bigger and smaller holes depending on what type if track or surface you are gonna be running on. They are great!
They are simply the most tunable and most durable shock you can buy for a savage!
