Bearing stuck in clutch bell
SavageSSBEAST
West Berlin Nj
My clutch bell bearings gave out so today went and got no ones took off the clutch bell and now the outer casing of the bearing is stuck in try prying it out with a screw driver and it didn't budge. Its stuck on the side of the clutch bell with the teeth
Just to add to what GOT NITRO said. You should be able to knock it out from the back using a small screwdriver or something. You need to support the CB over something so the bearing has got somewhere to fall out. A vice is ideal, but you might be able to sit it in a socket or something. Just put the screwdriver on the inner part of the bearing from the rear, and give it a gentle tap with the hammer.
Hope this helps.
Oh and by the way GN, you got your Caps Lock stuck on !! :slapped: :resp:
