beadlocks
Jay F.
chalmette louisiana
My madforce came with beadlocks. I was wanting to change out the tires. Wondering which types of tires work with beadlocks. Ive always glued my tires on rims. What do yall think? I want a more classic monster truck tire, like the chevrons
Are the wheels 3.2? if so any of the available 3.2 tires should go right on your existing wheels.....
What hex size do you have also because there are wheels available from Proline, Axial and a host of others so thats always another option for you to consider....
Well if looking for new wheels to go with your choice of tires Look into RPM 17mm hex wheels and you probably want the stablemaxx versions to add just a bit of width to your rig.....
I mount my wheels and tires using plumbers goop instead of gluing them with superglue so I can remove the tires if needed...
Check out this thread to see what I do....
https://www.hpisavageforum.com/threads/how-to-mount-tires-with-goop.13975/#post-174682
