Baja 5b gear mesh.
Paul Williams
Hi guys my Baja is working great at the moment may require a few tweaks ive replaced the nylon spur gear to metal as i stripped the nylon one but I'm a bit unsure if ive got the gear mesh there is a little play in the spur gear. Its hard for me to get a video could possibly get a few photos to see what you think. Being metal do you think i will be alright? Due to the fact its now metal?
I appreciate your feed back!
Cheers! (y) :)
Slight play should be fine, just check after every run!
what kg torque is the steering servo, is it the stock servo?
If that’s 65kg@6v & going by video seems to have enough speed/power! 👍🏻
