savagecre
Ok bought a set of four aluminum upper a arms. the turn buckles ( you guessed it ) BROKE AND BENT. But I like the look. so I drilled out the holes to 1/4 inch and pressed in 2" long 440 true STAINLESS STEEL ROLL PINS. and made them all just a couple of deg. shorter in length for Camber/Caster. Just got the front two done and figure that will be a good test now. I also put a SS roll pin in a vice and pounded on it really hard. It eventually bent but only after a very hard bash. The two that I have finished look cool too. so if anyone who has these maybe in there truck box cuz there tired this maybe a good option I'll post the results soon I'm going to be jumping off a ramp I have on the street so this should be a good test.
