Almost ready to race....
blowpopracer
Ok here is what I have......
HPI Savage 25
-Integy MSR4's Shocks
-Integy Adjustable Front Upper A Arms
-Tsais T Bones CVD's
-Integy Progressive Spring Set
-Fast Lane Machine Extended Low Center of Gravity TVP (+1 1/2")
-Fast Lane Machine Servo Mounting Plate'
-Fast Lane Machine Extended Center Skid Plate
-Fast Lane Machine Engine Mounting Plate
-JR 8550 steering servo
-Mid chassis fuel tank mod.
This Is what I have done so far to make the savage a good racer. Any suggestions on other upgrades to make it handle better or be more reliable?
Any tips would be appreciated. Thanks.
hows about shorting the shafts in your shocks too lower the whole truck even further, I've done this to mine and it hardly ever rolls and holds on real well, I took 15mm off the shafts. If you wana just try it without cutting the shocks as an experiment you can put fuel line over the shocks inside the shock body to stop it coming all the way out. say 15 or 20mm of fuel line on each shock. Just a suggestion. sounds like you've got most things caitered for though. You'll be ready for a race ;)
