So I got the break-in done, had trouble getting it started so a guy at the hobby store played around with the idle/low/high adjustments to get it thru the break-in.
I was thinking it was running too lean on bottom end and too rich on top end. . . when I would pull full throttle under acceleration it would stumble/studder and not really reach full topend(or what I would assume would be topend power).
So after some reading I decided to put all the adjustments back to "stock/flush" and retune from there.
At first I had trouble getting it to start, then once I got it cranked it would idle and die after a few seconds. .. played around with the idle adj. screw and got it to idle fairly well(or at least I think);
-Now when I cruise around at low-mid throttle and let off, it acts like its sticking and still leaving the carb opened up? I have to tap the break to kick it into "neutral".
-Also I still haven't got it to reach full top-end potential. . .?
-Then I pulled the air filter tube off and noticed the carb is fully opening up, and I can't seem to set it so that it will.
On the throttle servo arm, it should be set at a 90' angle, and the throttle adjustment knob on the trans should be in neutral, correct? If the idle is not correct should I be using the knob on the remote or the idle screw to make it idle properly?
This is probably covered somewhere in here but I've been searching thru SOO much info on here it gets hard to find. So if you can any help for this noob is appreciated.
