Added some LED strips.....
santiago
1399093712285.webp 1399093786125.webp Added Some LED strips to the bottom of my savage today...its a Mickey mouse job but it works...the strips work perfect and fit flush undernieth...just kept everything that came in the package with the exception of the test button....I switched that with an on/off switch..velcroed the small battery box and switch and zipp tied the rest of the wire...I kept it cuz I wasn't sure If it was gonna work...I also ordered a Dusty Motors Shroud today...that will hopefully keep the water out...
Looks like they do a pretty good job lighting up the truck too.
Are those the waterproof lights?
The lights work ok...but just for ground effects....the blue color is kind of dark and hard to see at night when you are far away...I bought some other LEDs to light up the top...which is better cuz it lights up the body and you can see it better from a distance...also...after running it in the dirt and grass at top speeds...the Leds at the bottom got destroyed...
