Adapater for charger...
I am going to be pruchasing this charger and was wondering if anyone could tell me where I can get or if they make a adapater so I can charge my hump pack.. :resp:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=220443507451
Whoa that looks just like my prophet sport charger except the prophet has clips instead of a cig plug for 12vdc. The adapter in the back looks like a Tamiya to futaba. If that's the plug on your hump pack it should work
I checked it out at the lhs and it don't come with the adapter to charge hump packs like the one that I have..Looks like that would work Londoner..
Just wanted to let you know that when you are charging receiver packs, you should charge at 1A. Anything above is way too much and will decrease lifetime. I charge all my batteries at 1-1.5A and they are all still alive now.
should theoretically charge a batt at 1c a expample is 1600 mah hump charge at 1.6 amps or 1100 mah at 1.1amps
I love the Squid. It's so convenient to have. Everything I need all on one plug. I had to change the banana plugs to Deans though because my charger doesn't use female banana plug outputs.
its a lot more $$, but if you have any way possible to save up & buy a hyperion, do it! charge all your batteries with 1 charger. AC/DC & too many other bennies to list http://www.amainhobbies.com/product_info.php/products_id/18361/n/Hyperion-EOS-0606i-Li-NiMH-A123-AC-DC-Balancing-Charger-6S-6A-50W
Get the squid too, all your charger jacks on 1 lead http://www.amainhobbies.com/product_info.php/products_id/35606/n/Racers-Edge-The-Squid-Charging-Adaptor
That is something I will look into for down the road frddy.
