4 shoe clutch
Crash
Chicago
anyone ever try a four shoe?
Features:
4 shoe 1/8th scale flywheel & clutch for SuperMaxx EXT Nitro Chassis
Fits most Maxx .21 Applications
Back of flywheel is pocketed, this helps shield the front bearing on the motor
A direct replacement for HPI Savage.
This flywheel is intended for the SM EXT (& other .21 Maxx chassis) owner who wants a better/stronger clutch and is going to go with the Strobe slipper and the 51T spur.
All but one flywheel on the market prior had space issues in this application. Diameter too large and hitting the chassis and pushed the clutch out too far making clearing the trans & lining up the spur very difficult.
You will need
An 1/8th clutch bell - I'm running the 18T on mine
Strobe slipper, bearing, etc
Ofna's Ultra 51T spur - available in plastic (OFN30110), Delrin and steel.
It's also a stock replacement for the Savage. Allowing it to go from the stock 2 shoe to the much better 4 shoe.
I was thinking about trying one with my new LRP. Are you going to install it Crash?
I cant find the artical that I read about them but it was something along the lines that they alu. is there for the hard grabbing and the plastic is there to give a bit of slip for the rpms to come up and then have the alu take over. Like said I don't remember but there thoerie sounded lagit. I will keep looking for it and if I find it I will post it.
