3 speed with reverse ?????
killergsxr1
i just picked up a used XL and took apart the 3 speed for inspection and it has the reverse setup in it..i hate the reverse and want it gone..what do i need to get ride of this reverse...
best bet is to download the manual for the reverse from hpi reverse process to remove it , it's rather simple , you may need one part to cover the hole hole and a screw.
if you want, you can also just lock it out. Remove the servo from the radio box, and lock the rod in place, or even easier, just unplug the servo that engages the reverse... and when you are done, send it to me 🙂
Here is the link to the reverse module:
http://www.hpiracing.com/instructions/instruct-savrev.htm
Here is the manual for the XL, which (I am pretty sure) comes with the 3-speed stock:
http://www.hpiracing.com/manuals/pdf/104246.pdf
Hope this helps!
Bob
removing it is by far the best and safest way ,
you could be like me and just unplug the servo Doesn't help top end though , and I good jump rock or what can slid your linkage and blow up your transmission ,
I would just remove it and be done with it , 😛annedout:
