3 speed tranny adjustments
Hi!
Welcome aboard!! Are you asking about 3 speed adjustments? You will probably have to adjust it.
I'm assuming you have your truck reasonably tuned, the tranny's use rpm to shift so you should be well tuned first.
Two problems I've run into; not starting in first, if you cannot wheelie (and could with your 2speed you are probably starting in second.
the second common problem is jumping from 1st to 3rd.
I had the second problem, I adjusted my shift 1-2 later once I heard that shift, I moved the 2-3 earlier until I heard both shifts.
I can't emphasize the tune enough..
cheers,
Leslie
Ive had the 3 speed for awhile and when the new center case from the X was released I was very excited! Soooo much easier if your still trying to get everything adjusted. You have to still remove the gear cluster from the case to adjust the 3rd shift but before the new case what a ordeal! Had to pull the entire case out, now just 6 screws and the top pops off revealing the gears.
