It is equipped with a 3 speed but I need some base settings so I don’t have to keep opening up the gears to access the 1-2 clutch.First off are you sure your rig has a 3 speed gearset inside, you have to pull the top cover to get to the 3speed gear adjuster if I remember correct, but at any rate I did find this by searching 3 speed settings in the handy search bar.....
https://www.hpisavageforum.com/threads/3-speed-transmission-adjustment.19984/
Thanks buddy, check out my other thread where I need help.Setting for factory setup are.
2nd gear 4 and a half turns out.
3rd Gear 3 turns out.
Most settings say, set from flush, but easier to wind all the way in then back out by the amount of turns I have stated.
But this also depends on what clutch/spur you are running.
Also if your mill isn't tuned right then it won't shift right
No worries friend, Always here to help fellow Savage nutters, If you got any questions just post or message direct. Have 9 of the beasts my self including 2 savage 25s, 2 savage K4.6HO, 2 savage F4.6, 3 savage K5.9s.Thanks buddy, check out my other thread where I need help.
