2 new FLM alloy bulks. #FLM40010 & FLM40020
Londoner
c0ckney geezer!!
London, UK
FLM40010
XL Hybrid bulk.
* CNC Machined from billet 6061 aluminum
* Includes new H.D. drive cups
* Bulkhead and diff case machined into one solid unit
* Machined from billet 6061 aluminum
* Eliminates stock bulkhead and diff case by combining into one unit
* Eliminates chassis support at TVP mount
* Eliminates bulkhead brace
* Superior strength
* Weighs 191 grams
* Includes all necessary mounting hardware
* Accepts stock gears with no modification
http://www.fastlanemachine.net/proddetail.php?prod=FLM40010&cat=22
FLM40020
Super hybrid bulk
* New! Super Hybrid Bulk
* BULLET PROOF YOUR SAVAGE
* Fits Buggy style diffs
* Fits CEN diffs
* Diffs are a direct drop in no shimming or mods necessary
* Most diffs will work
* Diff must be 38mm +-1mm in diameter (ring gear)
* Bearing diameter of 16mm
* Distance between bearings 34.5mm +-.5mm
* Any diff that is within these numbers will fit
http://www.fastlanemachine.net/proddetail.php?prod=FLM40020&cat=22
Anybody know anything about these?
Sorry i have no pics, theres no pics showing yet for the XL bulk and the pic for the super hybrid bulk is the same pic as the old standard hybrid bulk.
http://www.fastlanemachine.net/products.php?cat=HPI+Savage
So is the XL bulk the same as the old bulk but with smaller outer diameter super heavy duty diff cups, so you have to you use their cups with your XL or Flux or have they opened up the hole in the bulk to accept standard size XL/Flux cups?
And the super combo bulk, buggy diffs? The outer diameter of the diff ring gear must be 38mm -/+ 1mm? I assume thats the smaller CEN diff ring, stock ring is 42mm. Distance between bearings of 34.5mm? I make the distance between the stock diff bearings about 24mm, I'm confused lol
So you still cant use standard XL/Flux SHD cups in the new bulks? Do the FLM cups have the ID for XL/Flux bones or regular bones?
