2 gear problem or is it?
hi went out bashing yesterday was all going fine till i went through a puddle but i think it was a coincidence when it pulls away its fine till i seams to change gear then it just finds a neutral and maks a rattling sound ive got the gearbox in bits but no signs of grinding anyone got any idea? thanks reg
So its having issues changing gears but runs fine when in first gear? Check the clutches and make sure the adjustment screws are in place, or not loosened to much.
I would check the slipper nut tightness. With the info you gave Id suspect that over most things it could be.
