16/52 gearing with flm?
sharkattack99
Moses Lake Wa
Is 16/52 gearing possible with the flm tvps and flm motor plate? I'm running 16/49 gearing now and it really tight was not much room for movement in fact pretty much no movement just enough to get the messy right.. I want to go XL stock gearing but was wondering if it would fit thanks.
Shark
I run 49/16 and can tell you its really tight. I tried giving my mesh a little more room, but your not going to get much to put a 52 tooth in there.
Part of the problem is the back plate to the motor touches the TVP. You can grind on either or. Also you screw heads will need to be button head with a little grinding oon the cross bar of the TVP.
