Form
I've received my Savage X SS 4.6 two days ago (my 1st hobby RC) and I've spent the last two days building it (awesome!).
I have run into a few strange things / problems though. Could someone enlighten me? As soon as I get the answers I'll be able to continue building it (almost done!).
1- Pulling the pullstart on the K4.6 is very difficult. When the glow plug is removed, there is no problem (although there is some resistance at the top of the piston's travel). When the glow plug is in place though, it seems like compression in the cylinder is VERY high when near TDC, making the pullstart very hard to pull. What could cause this / is this normal? I'm pretty sure that the Savage would lift off the ground if the engine was attached to it and I was to try to start it. I haven't touched the engine except from removing the needles to add some green slime, removing the crankcase plate to add some gasket material and removing / screwing the glow plug back in. The inside of the engine seemed well lubricated so I haven't bothered disassembling it completely.
2- There is no indication in the manual on the amount of force to use for the clutch bell screw (the one that maintains everything in place). When I tried to screw it in completely, it was like the clutch bell was "glued" to the flywheel. To get the clutch bell to rotate freely I had to unscrew it until it barely made contact with the spacer. Is this normal?
3- Shocks. I stretched a cap o-ring for one shock (don't ask me how I did it, it simply warped inside the cap somehow :duh🙂 so it leaks all over the place; I'll have to get some replacement o-rings.
Second, one of my shock bodies has a hole in it. Where the shock body was attached to the mold, there is a microscopic hole which leaks oil like crazy. Another discarded shock.
My questions regarding this:
- HPI's warranty: how fast? do I need to ship the part for them to evaluate it?
- Could I run the truck with only two front shocks for now? (no 10ft jumps of course). Does that put too much stress on the two lone shocks?
4- How much thread lock to use? Do I apply a light coat on the screw, or do I drown it in thread lock? (I know it's a bit late to ask, but better late than never!)
Thanks in advance for your answers! :resp:
