The easies way it to upgrade the throttle linkage to the OFNA style one. Also replacing the servo with a more powerful one will help. The servo saver just needs to be removed.
Welcome aboard by the way.
I just got a Savage XL and i think the brakes stink. It takes about 35 feet for the truck to stop. Are there any better brakes out there i can get for it?
Thanks
-Mark
I will say one thing. if you are using the 4 AA battery pack, upgrade that first. I put in a hump pack into my 4.6 and it was like night and day. My truck also took like 35+ feet to stop it was ridiculous. But now with the linkages still stock and the brakes cranked down a little, I will flip end over end if I slam on the brakes. The hump pack makes the servos that you got work better.
Then if you want to upgrade your linkage and servos, go for it. The battery to hump pack IMHO is the first thing that should be upgraded. I went with a Reedy 1800mah hump pack. It lasts all day.
BTW Welcome to HPISF
good advice magoo, +1 to you bud. also, your gonna get more 'smack' out of your servos with 6 volt vs 4.8 volt
