xtremsavage
OG HPISF MEMBER!!!!!
- Location
- Jacksonville, Fl
Ok guys, since I really tore my truck up a few weeks ago and had to do a full rebuild, I had to use my stock TVPs (non-X) and still wanted a mid-tank. So, saving money for a better set of TVPs I went the old-school route. I've only spend about $75-85 and that was for parts I needed. For those who don't know what I mean by old school mid-tank, I'll explain. When mid-tanks first started, all people did was clear out the room in the stock radio box to fit a tank. You still used the stock steering servo mounting location, steering post mounts, and still able to mount the Rx in the radio box for a little extra protection without having to mount another box for it. I'll still be keeping the battery box mounted to the front shock tower since it's already installed there. The parts I used for the mid-tank are as follows ,I'm sorry to say this, but the parts I used are Traxxas parts (all the LHS had in stock and didn't want to wait for orders to come in), Revo fuel tank, Revo fuel tank mounting kit, and a body post set. I'll add the part numbers later for those interested. I also used the RPM servo mounts that I already had. Ok, time for the pics, and I'll explain about each one.
Pics of partially assembled truck
Gutted radio box (cleared out) with steering servo mounted. where the steering posts attach to the radio box is where the Rx is gonna sit.
Modified tank mount w/ RPM servo mount and modified bosy post mount w/ RPM servo mount. One of the RPM mounts had to be trimmed down. I'll post which one it was later.
Radio box with servo and tank posted installed
Fuel tank mounted in radio box from different angles. Since the pics were taken, I've moved the tank closer the transmission end of the box to give more room for shock tower flex. I also believe that the Rx is in the box in one of the pics.
In this pic, the radio box is mounted in the truck. You can see how close the tank sits next the the shock tower, hence the reason for moving it back some.
I'll update it more once I get more done. Hopefully by the weekend. Thanks for lookin.
