Hey everyone,
I just wanted to know what clutch bell you guys would recommend for me. Its for a savage x 4.6. I'm running the 3 speed tranny w/ the high speed third gear and i'm running 18/47 right now.
I called HPI because it seemed like the savage was running on one gear. They recommended lowering the gears, they also said i can try retuning the tranny. They said to tighten the screw all the way for the 1-2 gear, then loosen it 4 1/2 turns, they also recommend that same setup for 2-3 gear. But they said most likely i have to go lower on the gear.???
I want to try avoiding changing the spur gear, so what CB would you guys recommend would work best. Also, should i get one of the regular vented CB from HPI or is there another brand/type that works better?
Thank for the help.
Thank for the help.
