Would this tank possibly take care of the half lean problem?? It is a little pricey but what do you guys think??
ok i thought the bottom had to be the same size as the top i didnt realize that it was the shelf causing the issue thanks for educating me!! 🙂
I'm curious, If it is true that having the bottom of the fuel tank lower than the carb contributes to the half tank lean then why is it that most truggies and buggies have the bottom of the tank way lower than the carb.
What buggy or truggy ? the ones I have are far from as low as the savage. They are all on the same plane and the tank has no part above the carb. Read more... I said do to the preasure and the position not one or the other. The two together make the issue. The low tank in a savage takes more of a preasure head than a pipe can supply. and half of it (the upper tank) is level with the carb giving it too much. They are narrow and short on buggies and truggys giving more of a preasure head. Also not above the carb keeping the gravity swing at bay.
Siphon a gas can move the hose above the tank what happens.. it stops simple physics.
Now beach run a mill no truck. Holding the tank in your hand move the tank above the mill it will get fat now move it below it will lean out and that is within a second not half a tank. Also no measurable loss of fuel in the tank. So no preasure change. All simple physics. I did this test with a ofna tank and a Novarossi.
The same apply to all fluid dynamics The more empty the tank gets the more pressure to push the fuel and the less it gets do to the preasure head. You can tune a savage tank to run just fine on the bottom of the tank. But it will be fat on top. Its a poor tank design and position. But if you raise it it will work fine. there is less of a change in gravity on the tank.
Also for bashing there is no real reason to race tune a mill to the point this issue will hurt it.
Also for freddy some mills are much worse than others. I cant explain this. You may have had a leak in your tank(Oring in cap or a line). That is the only reason I can think of that you could not run it at all. it should have held a tune for at least half a tank top or bottom.
Long story short this is Off topic.
Why does not even matter. Some savages have it and bad, some do not, and some have a mild case of it. If you have it lose the stock tank any way you can afford to. If you don't be happy you don't and run it till the cows come home! I prefer the mid tank conversion do to the central and forward weight it gives the truck. But in the end lose it anyway you can and get bashing !
Only off topic caz the thread starter is not asking why. Just how to fix it.. people keep blaming its shape. Its shape would and does have no effect if mounted in a different location. I was just putting out the fact that it is not the shelf (shape) that is the main cause but is playing a role.
