here are a few company's,
http://www.massivemods.com/ ,
http://tntmods.com/ ,
eb mods but the will only do new motor's
http://rbmods.net/
Yes I usally port the sleave and polish it to. The crank in the pic goes to a Star .25 , I did a full mod on this motor only because I had the spec's to go by. The piston sleave was ported, the exhause timeing was changed from the stock 156 duration to 170 duration. the piston skirt was noched out so the the bost port in not blocked by the piston at BDC. the crank induction timeing was changed from stock 188 to 210 mening that it stays open longer alowing more fuel. This made a huge diffrence in the engine proformance. it has a crisp throttle responce, more useable rpm 's from low to high and a good deal more power. It will idle pretty much threw a hole tank if i let it. temps stayed the same. a little diffrent to tune, but still tune's easy.
On most of my motor's ill port the sleave nothing majer and polish the crank. it make the motor run smoother, add's a little hp. over all better preformance.
I would say it would open your motor up, you would notice a crisper throttle, run's a little cooler, and should gain some hp, and a better power curve.
here are a few pic's of the .25 for some reson i don't have a shot of the port work on the sleave...
the piston after it was cut.
the crank indution after it was cut and in the final polish stage's
the block exhauset port had to be cut to match the new exhaust timeing.
If you are good with a dremal and your hand's it is not that hard to port the sleave and polish the crank. a mod shop could 20 to 30 % more power but will cost you 100+
I would say when i port the sleave and do the crank I pick up 10 to 20 % more, but if you do not feel comfy doing it. then don't lol
