Please Help
mulisha770
My Savage X 4.6
When I Full Gas It From Stand Still In Bogs But If I Put Gas On Lightly It Gos Fine What Do I Adjust???
yup u gotta tune your LSN until you have a trail of white smoke at full throttle. turn the needle at 1/8th turn increments.
good luck! and welcome to the forum!
Use the pinch test ..
Pinch the fuel line 1 inch from the inlet to the carb..
If it dies right away your too lean..
If it takes more then 5 seconds your too rich ..
If tuned right . The idle will raise for a short bit then die with in 2 to 3 seconds
Great info Jester! You took the words right out of my mouth....
good looking out jerster. that has to be one of the easiest ways. you get an A for the day LOL
What about when you floor it from a roll? If it does it then also, its probably a lean hsn.
Whats your def of bog? A rich lsn will be sluggish and slow, but no bog sound.
Rich sounds like a gurgel. Almost like its under water.
Lean will hesitate sometimes kill and give a stutter sound. Its fine under small ammounts but starving at full throttle.
great advice jester as thats how i check mine and it always works!!
