need help with ofna throttle/brake mod!!!
609savage
dirty jerzey
well, i had this mod laying around for about 2 weeks now and cant figure out what goes where...here is the pics on the bags of goodies i ahve but do not have an idea>>>please help...step by step would be great
X posted a good thread on the subject. But I will give you my short version, since it is pretty easy like X said. All you are really doing is bending the steel rod to shape. Mostly to get around the roll bar. Then you are not using the HPI "servo saver" type servo horn, instead you are going to use the spring on the rod, for the "brake give"! Look at this pic as well.
Pic of mine.
I'm actually using the HPI stock servo horn, but I have glued and screwed the two pieces together so they move as one. I'm going to upgrade to just a alloy servo horn and using the sliders in the ofna kit. Just like in the other thread.
Nick
ofna help
I'm trying to install the ofna mod but one problem...the rod that connects to the ball hook thing...that goes to the carb... what came with the package is to small to hook into the ball hook thing i don't know what it is called! it is the shiny thing, witha hex head and is threaded...more explainable in the pics...:retarded:
Use what's in the kit. All you have to do is screw in the ball stud into the throttle arm. Then screw the nut on. Its not that hard. Yes the hole on the throttle arm is smaller then the screw on the ball stud, but that is ok, Man up, and screw it through. you will be fine.
I will attach a pic.
After reading your pic. If you are having problems with the ball cup going over the ball stud? Same answer, (Man up) Get it over with needle nose pliers. Yes there is a very tight fit between the ball cup and ball stud.
well in my kit it came with a nut but the nut does not fit with my ball stud...it is to big (nut) i guess i'll take a ride to home depot to get the right nut...
