post your hop up hear
Jeremy
tacoma wa
what hop ups do u have on the savay
mine include
surefire.32 (with nova raceing head)\
2 stage airfilter
3 speed
every clutch bell and spur gear the have
fule tank gard
head protector
dull disk ( but do use it) i like the stock better
roll cage
whellie bar
savage show pipe
4 gear difs
cam type stearing
Savage X handle with head procetor
probably forgot some
MY SAVAGE ISN'T A SHOW TRUCK
so I don't have many alum. parts because alum doesn't give. plastic does
and I want to bash the piss out of it and not let it become a shelf Queen
Ok adding some All heavy duty dog bones
heavy duty cup joints
Jt comtom Throttle linkage modd
Savage X
STS .30
STS tunned pipe
Alolly diff cups blocked and shimmed (shipping)
Savage x roll bar
New tires and rims 2 sets (shipping)
Hump pack
mine is in the process of being built...will post a complete list when finished...
Ok I have the Savage 25 with:
3 Speed
Reverse
STS .28
X Rollbar
Fuel Tank Guard. ( Thanks HOP )
HPI Ribbed Pipe
Motor Savaer Air Filter
And extra's
two stage filter
hotbodies pipe
hitec steering servo
rollcage
gold tvp
xtm 247
5 cell reciever hump pack
hummer body
titanium dogbones
bow ties
What do u have so far and what are your plans for it
all aluminum suspension (i know...i know...i've heard it all before...if these fail me, I'm thinking the titanium Flex Tech arms)
Hot Bodies .46 Truckzilla motor wit 2 stage filter
1" extended Truckzilla TVP's
CVD's
aluminum wheels
basically, completely alloy, except the battery box...
it's gonna be my basher...my racer's another story...
CVD's
aluminum wheels
I price the titanium arms before and ther were like 300dollars holly ****tt:eyecrazy:
quasi fibre carbon fibre low centre gravity tvp's
fastlane buggy style shocks towers
fastlane lower arms
hpi adjsutable upper arms
alloy knuckle arms and c-hubs
hellfire wing and mount
dual disc brakes
heavy duty dogbones
40 series moab tyres
40 series brickpin tyres
streetsweeper road tyres
all standard purple alloy parts stripped and painted black
+few other bits n bobs that i cant remember
here are my hop-ups, first buy first:
servo saver bearings
HPI`s alloy clutch shoes ( soon to be replaced by nova`s )
HPI wheeliebar
3-speed tranny
HPI super mudders
nova coolinghead, enginemount and diff-cups.
that`s it for now but there`s more to come.
fastlane lower arms
dual disc brakes
heavy duty dogbones
YES!!! lots of aluminum!!! so tell me, do you bash with it? or is it a shelf queen, like everyone says they become when all alloy?
mine is set up for racing. the shock towers and lower arms together give me excellent options for shock postioning and using various types of shocks.
the shock towers also don't flex any more so i don't burst my fuel tank every time i jump. (nut and bolt at top that holds shocks on flexes into the back of the tank on bigger jumps with the plastic towers) i went through a couple of tanks just because of this.
the lcg tvp's also stop if from rolling over on every turn. It races better than most savages at my club, however at the end of the day its a savage and I'm about to reuse it as my basher and build a revo for racing.
ok...got "most" of the things I'll be using for my monstrosity...eBay is a wonderful thing, although i STILL dropped around $400-ish...
all alloy suspension and steering
Fastlane extended LCG chassis
alloy tranny housing with 3 speed and reverse
alloy diff housings with steel spider gear setup (x2)
alloy bulkheads
alloy shock towers and body mounts
.46 Hot Bodies Truckzilla engine (in need of a rebuild) on a Nova racing Motor mount
Alloy wheels
CVD's all around (except for the extended one necessary for the Fastlane chassis...anyone know if they make an extended cvd?)
currently the only things that will remain plastic are the radio/servo box and the skid plates/bumpers...
Originally a Savage 21, now has:
Picco .27
3-Speed
Reverse
HD Dogbones
HD Drive Cups
OFNA buggy air filter
Failsafe
Airtronics 358 steering servo
Hitec 625MG throttle/brake servo
OFNA throttle linkage mod
FLM engine plate
4-gear diffs
HPI steel spur setup
Custom-painted body
Usually run on Bowtie tires mounted to T-Maxx wheels
HPI wheelie bar
Cam-style servo saver with bearings
Adjustable upper arms
Adjustable turnbuckles
my project truck I have been building for a few years..Here are some of the things Ive done to it and instaled...
hitec 945mg steering servo, hitec hs-5645mg
Kanai servo saver and bearings Moded
Aluminum bulkheads front and rear
Crazy nuts dual brake kit
Aluminum hubs front and rear
Aluminum hub supports front and rear
Titanium trun buckles and hinge pins( lunsford punisher)
Aluminum bulk chassis braces
fastlane aluminum diff cups shimed
shimed 2 speed tranny
shimed drivetrain
ofna trottle linkage, and dynamite aluminum servo arm, and quik clips
hexcrews screw kit
venom temp gauge, fail safe
1400 NiMH hump pack
CEN shocks
Twisted Toys .5 lowered and ext. tvp, with TT rear dog bone
mip shiny cvds front and rear
musle front center cvd
motor saver air filter
OS .30, nova clutch shoes, nova engine mount, moded hotbodys engine plate.
tuned 1 peice pipe
savage X a arms
charge jack mod
savage x roll bar
ofna clutch kit
Ford 650 body
x-75 beadlocks
fully moded star .25 with nova head my bashing motor
various other little parts I'm probly forgeting.....
Here is a link if ya wana check it out.. https://www.hpisavageforum.com/forums/showthread.php?t=1070
u also should post pic of the truck SOUNDS AWESOME (smaller pic would be best) thanks man
suppose i should change mine now that the savage is gone 🙂
revo 2.5 upgraded with:
vantage extended carbon fibre chassis
qoncepts engine brace
jd carbon pushrods, shock rods and hinge pins
rpm dyable arms and axle carriers
hard annodized gtr shocks
all colors of shock springs
p2 rockers
3.3 centre gearbox casing
centre diff
rear brake kit
tsais hardened cv driveshafts
vantage cv centre driveshafts
tekno-rc battery/rx box conversion
tekno-rc throttle servo mount
tekno-rc wing mount
proline high downforce wing
hellfire wing
hellfire fuel tank
maximizer hardened steel diff cups
robinson racing hardened ring and pinion diff gears
trinity lightweight 14mm hexes
motorsaver air filter
poline aluminium steering arm
traxxas heavy duty servo saver spring
Pro-line low profile 40 series mulchers on 1/2" offset dish rims
Pro-line 40 series bowties on 1/2" offset dish rims
Hpi El Camino bodyshell
Parma pse paint masks
Je-Spares hi-tensile screw kit
RB 323TM racing engine with starter box backplate
RD Racing Starter Box
Futaba 3010 throttle/brake servo
Hitec 5955TG steering servo
Futaba 3PK radio system (soon to be replace with 3VCS system)
If i was to list all the parts on mine three pages and $2000.00 later everyone would be asleep. ill just say it's got a picco .26 everything is purple aluminum and yes i bash it.
rite now all i have are
HPI Wheelie Bar
Savage X Update Parts
Dubro inline fuel filter
i will be adding lots as i go and i will keep you guys updated
