I traded for this Savage earlier this year. After running it for awhile and breaking diffs, shocks and bending the roll cage, I figured it was time
to build a better truck.
I found this forum and it helped me alot, thanks.
The Integy shocks were bending almost everytime out.
As a machinist I made some 4mm shock rods out of A-2 drill rod and then had them heat treated. I bored out the bodies to accept the new rods.
t"I also replaced the plastic spacers with brass at a much tighter tolerance.
They haven't bent yet.
I also bought 1" extended chassis plates (ebay for $18 w/ dogbone)
4 gear alloy diff upgrade f+r
Free mach .26 motor from friends LST2
Made some .75" wheel spacers
1500ma hump pack
savage X rollbar and engine guard
Added new wheels and body
Heres the truck as I recieved it:
(I don't like purple either)
Heres the bent cage.
After I straightened it, it bent easier, so off it went.
Heres the new setup:
Future plans:
3-speed
.32 axial, OS .30 , or lrp .28 spec 3
Lst shocks if these don't work out, I can get free stock ones
Rpm A-arms to cut some weight, only if these bend though
Any other suggestions/opinions please
1500ma hump pack
Future plans:
3-speed
