HPI 4.6 v2 Engine Starter Spring and Pin
Dazn
Hi All,
Really stumped.
Got a HPI Savage F4.6 v2 and manual in front of me so absolutely sure this is the engine.
Am trying to reassemble the backplate with part number 1433.
How on earth does the starter spring and pin sit when you install the backplate.
The spring seems to long and the pin won’t stay without flying off.
The spring goes into the hole followed by the pin in the part of the crankshaft that the conrod rotates around.
The face of the starting shaft then butts up against the pin when assembled.
Has your spring been stretched?
Yep did that - side by side the spring is longer than the pin - when the spring is in the hole it is sticking out loads
The pin sticking out is by design.
The little groove in the flat end of the starter shaft is how the pin engages with it to turn the crankshaft to start the engine.
The spring will compress when you put the backplate on.
Once the backplate is in place, you should be able to turn the engine over by spinning the shaft one direction and not turn over when you spin the shaft the opposite direction.
Will get some photos. To help explain. When the spring is fully compressed it comes to the same size as the hole in the con rod, which means there is no where to place the pin. It’s almost as if the spring is too long or the hole needs to be deeper. Must be missing something. Absolutely stumped.
Spring in the crankshaft doesn’t go in far enough. Wonder if wrong parts?
The starter pin and pressure spring are brand new. Got a knitting needle in there and used some spray - can’t see or feel anything to suggest the hole is blocked - just can’t figure it out. Only thing I can think of it is the wrong sized spring.
Just taken the back plate off of my k4.1 and the pressure spring is the same size as the new one I am trying to fit - so can rule out the spring it seems. The hole in the k4.1 is deep enough and I can see that it makes sense. There must be something going on with the crankshaft on the f4.6 v2 then I am guessing
Not sure if these photos help but trying to show that it looks like there is an extra bit of hole for the spring to fit into on the 4.1
If anyone can shed some light then that would be great - save me stripping down the engine unecesaarily - only other thing I think of is perhaps it is a different crankshaft?
...perhaps it is a different crankshaft?
I would be surprised.
What exactly is occurring?
Is the pin sticking out so much that you cannot install the backplate / torque it down ?
Is the pin sticking out so much that it won't stay in place for you to try and install the backpplate?
