Novarossi carb
Vinni
Help me out guys does any1 no of available replacement dustboot for the novarossi 3 needle carb ?🙏👍
Hey Vinni,
As near as I can tell, the carb on the current production Nova engine is a match for the old Novarossi carb.
The part number for the dust boot is NV-1802014 and is listed on Amain (back order at this time though) and is supposed to also be available via Hobbytown too (at least here in the States).
Hey Vinni,
👍nice 1 mate i wo thincking it wud be the nova 1 n shop over here in UK got sum in stock 👍👊
Hey Vinni,
Just got a new Lrp 32 4.1 wo doin a teardown n conrod will not come off tried all the tricks no joy ? You ever add this prob ? 👍
I've had at least one that didn't want to play nice.
Do you have any pics of the current situation?
Were you able to remove the cylinder?
Put it back together now cudnt get the rod off tried all the tricks no joy after run sum tanks fru it n try again felt like there wo a ruff spot on the pin tbh 👍
N ye sleeve came ou no probs rod n crank will not part company 👍
You may be right in running it some before trying again, just to give it enough "slop" to come off.
Did you try both TDC & BDC?
I've resorted to using forceps - but they can mar the conrod, even if you're careful.
Doesn't look good, but it wasn't a world-ender.
If it happens again in the future, I'm thinking of trying on using thread or fishing line to pull on the rod (the lower middle portion) while using my fingernail or something non-marring to pry the conrod's bottom end. Attack from up and down.
👍tried small ziptie n at BDC it’s in the groove -channel only opens up at top between 10 am to 02 pm kinda fing ? 👍
