Gents,
The rotostart axle hole of the F4.6V1 engine is located in the top-left corner of the engine backplate when viewed from behind, enabling perfect alignment of the rotostart axle. See picture.
Here’s the thing: I’m planning to swap the stock engine for an LRP ZR.28 or ZR.32 engine. On this engine, the rotostart hole is located on the left side of the backplate, but not in the top-left corner — it’s positioned more vertically in the middle of the backplate.
My question is: will I run into problems starting the engine since the rotostart axle won’t have a straight path past the shock towers and other components, unlike with the stock setup?
What do you think?
What do you think?
