Jaysavage2026
Hello, I have a hpi savage x f4.6, I’ve noticed when it’s running there is a hissing sound from the top of the engine heat sink, I’ve tried the carb spray to see if there is a change in engine pitch, but nothing.
the idle gap is roughly 1mm by eye, I’ve got the lsn set so it idles, if I rev it the wheels turn fast and carry on turning for a little while even after I put the brakes on, it does eventually settle down, if it files for a little bit it seems to bog initially.
I’m not sure if it’s an air leak or normal? I can’t recall seeing an o ring behind the roto start plate or back plate if I’m honest, what should I do
