Your engine's temperature will be low when idling and with no load. Presumably, with a rich setting which again will result in lower temperatures.
The purpose of break in is to allow the piston (which is ring-less) and the chromed liner to 'bed-in' to each other - but at normal operating temperatures. The piston and sleeve are tapered towards the top. At top dead centre (TDC), the piston and sleeve should be at their tightest.
One concept is that modern CNC machining is so precise, that it largely eliminates any need for running-in process with ABC engines. However, the counter argument is that the purpose of heat-cycling your engine is NOT to wear parts in as such, but to
"relieve the internal stresses of the metal parts that occur during the manufacturing
process."
This is quite an abstract concept to grasp, so we'll stick with the terms 'bedding-in' or 'conditioning the piston and sleeve for prolonged use' as the purpose of running in an engine.
When cold, competition glow engines can be so tight that they actually stick at TDC.
What can happen if you allow the piston and sleeve to wear in at lower temperatures, is that when the engine reaches the higher, optimal temperatures attained with 'the perfect tune', as the sleeve expands, the interface between them can become sub-optimal and blow-by may result.
"The sleeve will start expanding to the proper design parameters at approximately 205 degrees F., however, this does not mean that this is the normal operating temperature; it only means that you need to always get your engine up to at least this temperature as quickly as possible after the engine is started. Surprisingly, many companies today still recommend the old fashioned way of breaking in an engine [running in at idle with low load and a rich setting] as described earlier in this manual, but we have found that our method not only makes more common sense, but helps your engine run much better and with more longevity. The old-fashioned method of break-in; running the engine at low temperatures and very rich for several tanks, destroys the piston prematurely. By breaking in your engine the old-fashioned way, the piston actually “wears in” to the cool and under expanded sleeve size."
The best detailed instruction manual I have ever seen for any glow engine can be found here:
Fantom ABC engine manual - Nitro Engine Bible!!
Follow this guide and you can't go far wrong. This is the way to do it.
Furthermore, this details carb tuning, why temperature tuning is NOT the way to do it - rather, temperatures are a guide.
This is how I treated my engines since my RB WS7 engine, prepared by Stan Crompton. The tightest engine I've ever had. It was also the most rapid .21 size engine, ever.
It's how I ran this engine in:
It's a ripper! 🤩
