Raksasas
- Location
- Central Texas
Update from my original post - https://www.hpisavageforum.com/threads/i-have-had-a-savage-x-ss-sitting-around-since-2015.21023
I ordered the rotostart parts to replace the broken pull start that first week of July but...
July 11th, I was in a motorcycle accident caused by someone pulling out in from of me on a back country road. The Electra glide was totaled and left me with a TBI and broken leg. Well anyway... While in the down time, I got the pull start changed over to the rotostart.
About 3 weeks ago I finally got through the first tank break-in. I feel like that was rough. Every single time I removed the igniter it would die out... I started searching for the reason why and the closest things that I could find was pointing toward adjusting the low speed needle. I marked where it was sitting originally and gave it 2 or 3 very slight step turns, clockwise, which managed to keep it running for 1-5 minutes after the igniter was removed. I didn't measure how long but it was better than dying a couple of seconds after removing the igniter.
Like I mentioned in my first post, I built this thing years ago and it was/is my first nitro... I do not recall ever messing with any of the needles... high, low, idle screw. To the best of my knowledge, it was in its stock spot. Plus the Engine Manual saying to not adjust anything on it until after the break-in. So I do not ever remember "playing" with those... Except for just recently, the low speed to get it to run without the igniter...
After getting through that I started with the second tank which per the break-in was to start slowing giving it throttle. Well I didn't get too far into this.. It tooks a good amount of time to make it through the first tank... I filled the tank to start this second tank with slow throttle input but every single time I gave it any amount of throttle it stalled.. At that time, I needed to be somewhere so I emptied the tank and burned off any excess fuel in the lines.
Anyone have some tips for me on getting it through this second tank? Like I said it appears to stall when giving it some throttle. It starts to give some movement to the wheels but stalls out shortly after...
