Could you send the link to the alza-like diff mount. Thanks manI have recently purchased both the centre gear box with diff included and a copy of the Alza centre diff mount both from ali express . I have used the normal centre diff once but chewed the spur . The Alza fake comes tomorrow along with a couple other parts to fit it tomorrow. I can let you know how it is .
The gearbox version is OK but it still uses alot of internal gears from spur-drive gear-idler gear-centre diff .
I have already chewed a spur but it wasn't in great condition already as it was a old one I had . ( chewed my last good one before trying and centre diff options)
The Alza fake only has pinion-centre diff
Which should hopefully break less often as less gears to potentially chewed up but you need to purchase a couple other parts to make it work so ends up double the price of the gearbox version.
If you would like I can also find the links to all parts needed if you need mate 👍
https://a.aliexpress.com/_mr3tdykCou
