Found a comment a while back on another forum regarding running a center diff and gearing:
https://www.msuk-forum.co.uk/forums...pur-questions/?do=findComment&comment=2142199
Here's the standard flux gearing. For a CD, change transmission ration to 1. Put your spur at 48 and pinion to 11, change to 2000kv and select 4s, pick your wheel diameter. I'll guess you tyres at 6.3", it's suggested to start with a rollout ratio of 1:1 and see how temps go. So, 11/48 is around 40/60mph on 4/6s, 1.41:1, on the high side. 10/50 is 35/52mph, 1.23:1, better. 9/50 is 31/47, 1.1:1 better still.
http://www.scriptasylum.com/rc_speed/top_speed.html
So, would suggest your running really tall gearing for what the motor/esc is. The stock motor is a 2200kv.
I've had to gear mine down quite a bit to deal with heat when I started running 6S with a super 5SC transmission with center diff. It's got other gears in the transmission, so not direct gearing like a simple center diff would be. I had been running 4S with 20/44 gearing, but now on 6S, I'm running 16/48 and it's still on the high side.
