DOOBEEWHA
HPISF languist expert
- Location
- Petaluma,Ca,
Thats right....
A hot glue gun is very handy for special repairs. I'll list the one that fixed my fuel tank.
After discovering that I had a pressure loss in the return line from the pipe, I soon noticed a fuel leak that usually meant replacing, for sure......NOT.
Hair line cracks and cornners can be prepped with rubbing alcohol. After alcohol has dried, place hot glue gun at the fracture line and inject (if posible) the glue in the fracture. You can also just cover the fractured area with a bead of hot glue along the cracks and fractures.
Your done.
Check the tank for pressure leaks before use.
WA LA ! Repaired fuel tank. --------- You gotta "Fix" with a hot glue gun,...POST IT HERE.
Your done.
